Socket required for wheel nuts...
Feb 21, 2009
19
Being a bit lazy, can anyone save me a trip to the storage yard please?
I wonder if anyone can tell me what size socket I need for the wheel nuts on my Bailey Pageant S7 Provence? I need to pop to Halfords and pick up a 1/2" drive socket to fit the torque wrench I bought, and would like to save the initial journey to the 'van if I can...
Thanks in advance....
Vince.
Dec 6, 2007
414
Hi Vince.
I'll bet you a quid its either 19mm or 17mm!
I'm sure its one of the two but i can't remember which.
If you get no other replies just buy both & take the un-used one back.
Buy the way Halfords tools are brilliant, I'm a bus mechanic & loads of us use Halfords stuff.
Gareth
937
Unless Bailey are the only maker not to use the standard bolt size they will be 19mm
Feb 21, 2009
19
Thanks both. I managed to convince myself that I had a set of 1/2" sockets (of course, they were 3/8")!
I will take my chances on a 19mm...
Vince.
4,208
1,931
"Unless Bailey are the only maker not to use the standard bolt size they will be 19mmUnless Bailey are the only maker not to use the standard bolt size they will be 19mm"
Well those on my Hymer and the previous one are 17mm. Always thought they were the standard Al-Ko ones.
937
Quote "Well those on my Hymer and the previous one are 17mm"
But,Hymer is not made by Bailey............
And yes, import vans such as Hymer , Hobby etc may have different sized bolts, however the question was about a British van
My Hobby has 19mm bolts btw, and a BPW chassis.
951
All with AlKo or BPW chassis, and must be around 95% of all caravans, have 19mm wheelnuts.
Reg
Jan 12, 2008
435
My "cheapo" extendable wheel brace/lever has a socket with 17mm one way - turn it around - and it's 19mm. It has a 1/2" square socket in the middle.
Probably bought it in Halfords but can't remember.
Nov 29, 2007
667
It might be an idea to get one with a plastic outer sleeve. This will stop the socket scratching the lacquer coating off the wheel.
4,208
1,931
To steel spare wheel bolts are 19mm, the aluminium road wheels are 17mm as stated.
