solar panel connections help please/////
hi all have just bought a 40 watt solar panel from windand sun came with a regulator which has 3 set of terminals the first set is from the panel the second from regulator to battery and the third is to the 12volt circut my question is were to connect to the 12 volt system for t v lighting and pumps also should i leave the battery connected to the van via it's normal battery terminals i would realy apprecate your help and guidence i am a bit lost on this one and the instructions were not very clear thanks all peter
