- Jul 18, 2017
- 16,925
- 5,504
- 50,935
At the end of Sept we put the caravan into storage. On 12th Oct we were notified that the battery was low. On checking we found that we had left the 12v switch on even though everything else was switched off including the fridge. The battery was down to about 10.5v. We switched off the 12v switch.
On Saturday we went to the caravan again and found that the battery was completely flat. On checking the graph we could see that since the 10th Oct the battery had starting discharging until it was flat.
The solar panel and controller are both Truma and checking no green light was being displayed indicating that the battery was being charge. Between the end of Sept and about the 10th Oct the graph showed that the the voltage was going up and down indicating that the controller and panel were working okay.
We now suspect that the controller has gone faulty unless the controller shuts down completely if the voltage drops below 11v? I have a spare 110ah battery but do not want to install it in case the same happens to it.
