- Mar 7, 2024
- 4
- 0
- 10
Hi, i have just bought a solar kit. I am on a seasonal pitch with hookup. If i plug in, will i use solar or plug in electric or will it be regulated?
As no-one has answered I'll jump in with my 'best guess'. The EHU will power the battery charger to keep the battery fully topped up so the solar panel will be redundant most of the time (if the battery goes low during daylight both the battery charger and solar controller will charge the battery at the same time). Depending on your usage it may be beneficial to turn the battery charger off (if you can) so the battery is topped up from the solar panel.Hi, i have just bought a solar kit. I am on a seasonal pitch with hookup. If i plug in, will i use solar or plug in electric or will it be regulated?
There's little or no benefit in a solar panel WHILE you're on a hookup - if it's a metered hookup then there would be a slight reduction in energy consumption.Hi, i have just bought a solar kit. I am on a seasonal pitch with hookup. If i plug in, will i use solar or plug in electric or will it be regulated?
Who said it was a lead acid battery 🤔Letting a 12v lead acid battery go down to 20% will kill it in double quick time!
If lead acid technology, but if a Lithium technology battery, it may be the best way to treat it.Letting a 12v lead acid battery go down to 20% will kill it in double quick time!
Whilst what you say is true for LA batteries I prefer LiPh.
I could take it down to 5% and so long as I didn't do it every day it will still outlast me😉
I prefer 10 to 20% as it gives the battery an easier life.
Lithium Leisure Battery - Fogstar Drift 12v 105Ah
Lightweight 12V 105Ah LiFePO4 lithium leisure battery with Bluetooth, built-in heater, and 10-year warranty. Perfect for campervans and off-grid use.www.fogstar.co.uk
Hi Roger, we are charged per kw unit, like a pre-paid meter. Just thought a solar panel would cut costs. Thanks for your answerThere's little or no benefit in a solar panel WHILE you're on a hookup - if it's a metered hookup then there would be a slight reduction in energy consumption.
Thank you beardy, we are charged on the site with a pre-paid card for the hookup. I think I'll just use solar panels and disconnect hookup until solar power stops. Thank for your adviceAs no-one has answered I'll jump in with my 'best guess'. The EHU will power the battery charger to keep the battery fully topped up so the solar panel will be redundant most of the time (if the battery goes low during daylight both the battery charger and solar controller will charge the battery at the same time). Depending on your usage it may be beneficial to turn the battery charger off (if you can) so the battery is topped up from the solar panel.
The solar panel is charging the battery and the battery supplies the 12v to various systems, but it cannot heat the water or power the fridge. If you have any 240v appliances maybe some depending on wattage could work if using an inverter i.e. TV. Using it to power the fridge or a microwave will not work.Hi, i have just bought a solar kit. I am on a seasonal pitch with hookup. If i plug in, will i use solar or plug in electric or will it be regulated?
Thank you Gumpy, this helps. I'll turn off hook up when solr has power. AppreciatedI turn my charger off, and leave the solar panel on taking care of the charging, only switching the charger on if the battery gets down to less than 20%.
Tonight it's a 74% it may still be above 20% on Monday when we leave.
Only things on EHU are the Fridge, microwave and heating all the rest on 12v.
Just be careful not to run the battery down too far. I have some decent monitoring equipment on my system so know exactly how discharged the battery is at any moment in time, so I can sail close to the wind with it all.Thank you Gumpy, this helps. I'll turn off hook up when solr has power. Appreciated
