Sorry to bring up this subject again, but a search in the Forum doesn't answer my particular question......
My van - a Coachman VIP 545 with an 18 month old 110Ah battery lives in a storage site when not in use. It has a phantom tracker which requires a charged battery to be operational.
Although I switch off the 12v system and disconnect the radio when we leave the van, I find that the battery will not last much more than 6 weeks between uses before going flat.
It seems sensible, reading this forum, to get a solar panel which I could rig up to hang under the Heki rooflight or place in the front window.
The Maplin website implies that a 5 watt solar panel (currently on promotion) would be sufficient for this purpose and it says that I do not need a charge controller for batteries over 35Ah.
Is that good advice?
We do not need to feed the battery when away for weekends - we always look for a hook-up. And larger panels seem to be quite a lot more expensive.
I would be grateful for any advice.
Many thanks
Many thanks
