Solar panels
Apr 3, 2024
46
9
535
Hi guys I need some help please. I bought a brand new coachman 675 last May and after our season had finished the van sat in the outside compound. By December the battery was flat and unable to keep the tracker up and running. Has anyone had an issue with the coachman’s draining batteries ? I am told they don’t completely shut down
Oct 19, 2023
633
508
2,135
If you have a tracker it's continuously draining power from the battery.
When did your season finish?
Do you have a solar panel (as per the thread title)?
Apr 3, 2024
46
9
535
Tracker takes minimal power according to the supplier. Yes I have a soar panel that they fit before we had the van. I think it’s a 100 watt
3,796
The Phantom Tracker fitted to our Lunar Clubman flattened the battery in 2 weeks - so I found it, took it out and paid the extra insurance premium.
May 30, 2024
120
146
635
I've got a similar setup on a 2024 Swift. The tracker has its own battery which is supposed to be good for 3 months, and I imagined that the solar panel would be enough to keep the leisure battery charged over winter, maintain the alarm and so on. The tracker is also maintained by the leisure battery, but given that it has its own battery as well I didn't expect it to consume much.
I put in storage at the end of October, and checked the battery state of charge every so often (as reported by my tracker app).
In December I noticed the tracker battery level starting to come down from 100%, which surprised me a bit. By January it was reporting about 60% and so I went to check physically. I found that the leisure battery was almost completely discharged (and the tracker was functioning from its own battery only)
I recharged the battery and replaced it, and decided to experiment.
In October, I left the power control unit in the caravan switched 'on' (assuming that I needed that for the solar panel and alarm etc). When battery re-installed in January I switched the power control unit 'off', since it seems that might be what I was supposed to do.
A month has gone by and my tracker is still reporting 100%. I can't go and physically check the leisure battery at the moment (will do so in a couple of weeks) but I'm hoping that the rapid discharge was mainly my mistake to leave the power control unit switched on.
5,496
I wonder if something else other than the Tracker is draining the leisure battery?
I have no idea how your Coachman is wired. On my Bailey if the fridge is not completely switched off the interior light stays on when the door is left ajar in storage. Thus my battery flattened.
You need to check all the circuits and establish what is causing the drain. With such a new caravan I am sure your Dealer will check it foc for you.
Reactions: toad a caravan
5,445
Our batterey would last about 2 months and not two weeks. We fitted a solar panel on the Lunar and no more issues.
5,445
Are you sure that the master 12v switch is in the off position as that is the most common cause for a battery drain where a solar panel has been fitted.
Apr 3, 2024
46
9
535
Are you sure that the master 12v switch is in the off position as that is the most common cause for a battery drain where a solar panel has been fitted.I’m not sure it has a master switch apart from the main one on the control panel. I’m told by a caravan technician that the coachman’s don’t fully shut down. I thought the solar panel would’ve kept the battery topped up
Apr 3, 2024
46
9
535
To be honest the dealer is not the most helpful unfortunately. I think they’ve had my 40k and moved on
2,334
To second what others have said, is it completely switched off? On a Swift there is a Sargent electric supply box ( probably got a more technical name) under the offside front bench. On this there is a black button that kills the 12v supply when it is depressed. This is in addition to the master switch over the door. If you don’t leave it pressed when in storage the battery will flatten in winter when solar gain is low. The solar panel will still charge and it doesn’t affect the alarm. Whether or not there is a similar system on a Coachman, I couldn’t say.
Good luck
46
9
535
Good luck
Hi mel
The coachman has a master switch and I had turned it off but apparently the coachman’s don’t shut down as the swift and our old lunar delta ti. I’ve been advised to put an isolator switch to the battery but obviously after the solar, therefore anything going to the battery will be turned off but the battery should remain isolated and therefore keep the charge from the solar panel
Reactions: Mel
