I was thinking of buying a set of spare fuses for the 12v system, what amp fuses does the boiler and water pumps typically use.
I won't be towing, it's a Swift Challenger 524.
Remember some Muppet might have replaced the fuse in the fuse panel with a larger capacity one,, when they didn't have the correct one.Probably the safest bet is to either check your handbook, or maybe see what rating of fuse is currently fitted in your fuseboard.
Hence my initial advice re checking the handbook. (Or the appliance manufacturers website)Remember some Muppet might have replaced the fuse in the fuse panel with a larger capacity one,, when they didn't have the correct one.
