Spare fuses
Feb 6, 2024
130
33
585
I was thinking of buying a set of spare fuses for the 12v system, what amp fuses does the boiler and water pumps typically use.
I won't be towing, it's a Swift Challenger 524.
4,845
You can guarantee, no matter was fuses you buy, the one you need is not in the box.
Remember depending on your water heater there are small fuses in those.
Reactions: Richtee180
4,845
Probably the safest bet is to either check your handbook, or maybe see what rating of fuse is currently fitted in your fuseboard.
Remember some Muppet might have replaced the fuse in the fuse panel with a larger capacity one,, when they didn't have the correct one.
