Spares for a Dometic fridge?
Dometic RMSL8501 fridge. Unfortunately it seems that the person who uses the freezer part the most by stuffing all and everything into it and then pushing freezer door closed has broken one of the hinges. ๐Ÿฅฒ
Any one know where I can get another hinge to replace the broken one? Thanks.
Might be easier to change the offending person. ๐Ÿ˜‚๐Ÿ˜‚
Have you tried
They do spares for Dometic fridges. I got a plastic shelf from them a while back
for example
Donโ€™t know if it will fit yours. Not commenting on the price!
I did check Leisure shop but it is not available. Also looked at Camperselect while doing a Google. Eventually found it on Jacksons for under ยฃ24 delivered and place an order a few minutes ago.
Thanks for all the helpful advice. ๐Ÿ‘ ๐Ÿ˜€
