Sprite alpine relay chatter
Apr 5, 2023
Hi all, can anyone help with an issue I have just found on my sprite alpine 2008, I have just started to get ready for the new season and found when I filled the water barrel and tested the system I have got a relay chatter on the under seat fuse panel, when I run the tap the pump runs and water flows but when the tap is turned off the relay starts chattering and does not stop. Any advice would be appreciated
Peter
Jan 19, 2002
1,690
534
I presume that you can be sure the noise is from the panel - the only chattering I have experienced is from the inlet itself when the pressure switch needs adjustment - if yours is a Whale like this in the link
WhaleAdjustingyourpressureswitchb.pdf (whalepumps.com)
which gives clear instructions - the system may also need to be adjusted when changing from mains hook-up to battery supply. It appears from your photos that the panel and the plumbing are in the same vicinity but apologies if this reply is totally off-the-wall for you!
2,494
I think audiorob is correct, and I dont think there is a relay involved, just a micro switch.
Hi guys, thanks for your reply’s, I have disconnected the lead to the pump and substituted a triggering relay for it and the relay in the picture is the one chattering on the pcb, I believe a component has failed on the board and this is causing the issue.
3,241
Do you have a fully charged caravan battery installed and connected?
To expand that for the OP, the pressure switch is sensitive to battery voltage - if you're not on EHU the voltage will vary as the battery becomes discharged.
Apr 5, 2023
Hi all, this was a problem to accurately diagnose the issue and pull the trigger on the parts cannon,
Thankfully I messaged Apuljack electronics to ask for a quote to service the fuse panel pcb,
The tech support guys emailed me a tech guide as this issue is well known to them, i turns out that the pump control circuit is very sensitive to resistance on the circuit, long story short, I removed the cover on the pump pressure switch and found dried water stains inside, I removed the pressure adjustment screw hit it with wd40 relay stops chattering.
Big shout out to apuljack for the help with this,
Thanks to you all for your support
