hi all.
thanks steve but I will keep the jacket on for just one more post, john L wrote" The idea that adding a leaf spring will damp the pitching will have a limited effect. What it will do is pre-load the system and move the mean height of the pitching effect". this is probably true perhaps it is by moving the mean hight that makes it work I dont know it just does.
while the "in theory" point of veiw is valid it must be understood that it is not the whole picture and should not be taken as gospel or set in stone it is in practice and trial and error that solves the most problems as experienced caravanners know allready.
take van deign in theroy loading the van to capacity and within the makers guidlines every one on the road should be stable an perfectly balanced with nothing needed to improve matters just hang it on and go.
so why do we need a stabiliser at all? why do we need to to load the van low down between the axels, why is the nose weight not neutral on a empty van, why are all the heavy items built into a van ie. cooker fridge, toilet with 10ltrs of water flush, fitted right at the back as far away from the axels as possible with gas bottles and some times the battery right at the front. why are ALL vans not fitted with shock absorbers stiff side walled tyres and movers as standard and included in the plated MIRO and MTPLM weight, the answer is?. well I have no idea what I do know is that it left to us the end user to make whatever adjustments are required to make the unit as stable and as comfortable to tow as possible by trail and error and if that means adding a blade into the set up so be it.
colin
