status 530
Wendy - are you sure you are not talking about the omnidirectional aerial, which I think most would agree are c**p?!!
The new 530 directional gets a huge ammount of praise. So far I have found mine to be superb.
181
If that's the aseiral that's fillted to our split new Abbey Cardinal - do not waste your hard earned money on it.
Get a decent one on a Pole you can take with you and set up once on Site
Jul 25, 2005
164
James,
I have a status 530 on my van and don't use it because the signal is usually to weak.
If you would like some info re; different types of aerial try the link below:
http://www.practicalcaravan.com/product/jan05.html
Apart from a external aerial being cheaper and easier to fit, you will be able to get freeview,if you need it? providing you get a high gain aerial of course,
best wishes,
Pop
Apr 25, 2006
45
The stats 530 is like a breath of fresh air, but you do have to learn how to set it up. You need to understand if the area you are in requires a horizontal or vertical aspect, and only after setting this do a scan from your TV. After scanning it will require a rotation to gain the best picture.
Thanks to this aerial I managed to watch Englands efforts in the world cup from an isolated site in North Wales. The friends if ours with status 315's couldn't achieve a picture.
Jun 17, 2011
826
27
18,885
Our 530 is brilliant. never failed to get a signal even in mountainous wales. You need to raise it and rotate it. Soemtimes BBC2 is poor but a slight adjustment on the aerial always improves it. I ahve also found that extending the vhf poles can improve the picture, although it shouldn't do so.
Jan 21, 2014
1,245
We've used it a couple of times - really can't be bothered with it, or the TV!!
