does anybody know if the status airel is sutable for digital signals as I tried to use the digibox while away without any success but it works fine on analog tv
No Colin - one of the reasons that the Status 530 is better is because it's mounted on a pole which goes through quite a big hole in the roof, normally into a wardrobe or roof locker. (The 315 sits on top of the roof with a small hole to route the cable.) This pole enables you to adjust direction and orientation from inside the van and gives you that little bit of extra height which is often quite important. Look at the website at www.gradeuk.co.uk/products/antennas/status.asp for more details. In our case, we asked the supplier to put the hole in the same place as the previous mount. We have the 530/5 with the shorter pole but it's proved to be very good so far.thanks all I will look into it and let you know
by the way does the 530 use the same mount
thanks johnNo Colin - one of the reasons that the Status 530 is better is because it's mounted on a pole which goes through quite a big hole in the roof, normally into a wardrobe or roof locker. (The 315 sits on top of the roof with a small hole to route the cable.) This pole enables you to adjust direction and orientation from inside the van and gives you that little bit of extra height which is often quite important. Look at the website at www.gradeuk.co.uk/products/antennas/status.asp for more details. In our case, we asked the supplier to put the hole in the same place as the previous mount. We have the 530/5 with the shorter pole but it's proved to be very good so far.
Hi to all, I received my Practical Caravan magazine this morning and the issue of the Status 315 came up again. I bought a new Bailey Ranger last year and it was fitted with one as was 90% of the new caravans for sale were.No Colin - one of the reasons that the Status 530 is better is because it's mounted on a pole which goes through quite a big hole in the roof, normally into a wardrobe or roof locker. (The 315 sits on top of the roof with a small hole to route the cable.) This pole enables you to adjust direction and orientation from inside the van and gives you that little bit of extra height which is often quite important. Look at the website at www.gradeuk.co.uk/products/antennas/status.asp for more details. In our case, we asked the supplier to put the hole in the same place as the previous mount. We have the 530/5 with the shorter pole but it's proved to be very good so far.
