Staus aerial
Is it easy to remove the aerial from my caravan roof, I think it is a Status, (circular shape). I am going on a ferry and have been asked to remove it but I think that clearance will be ok but may have to remove it at the last minute before boarding.
Its usually enough to remove the pointed bit on the top by unscrewing it.
You can remove the main body by loosening the grub screws at the base and unplugging the coax lead but this is not something I have ever had to do in lots of crossings with different companies. The Status comes with a plug to put in the hole.
Depends which ferry you are going on, some need the spike taking off, if its the Isle of Wight ferries, dont bother, there is plenty of clearance, just tell the load master at the dock and they will put you in the right place.
Thanks Damian, yes it is IOW ferry (Wightlink), so I won't bother now. Also, are you the Damian who offered to describe the changing of a water heater element in a Truma? If so, please go ahead and tell me how to do it. Cheers Tony
If the Status aerial was factory-fitted, the caravan manufacturer probably won't have supplied the blanking cap when the caravan was delivered new.
Tony, hope you have a good holiday here on the Island. As for the heater, its a bit fiddly but pretty easy. Make as much room as you can to get to the tank, follow the black wire to the location of the heater, then use a stanley knife to cut the cardboard shroud to allow you to open up enough room to work on the element, but dont cut it off completely, just a + shaped cut is enough. With all electric OFF, and disconnected, use a small socket to undo the two nuts holding the heater in place and the thermostat which is connected to it. If you have, or can borrow a socket which goes on a screwdiver handle instead of a tommy bar, so much the better. Use something like a bit of vaseline or even chewing gum in the socket to anchor the nuts as they undo, to save them falling off and rolling under the tank, same when putting them back on.
once the nuts are off, cut the black wire about 6 inches from the heater element and strip back the leads on the piece remaining in situ and connect into a terminal block, preferably in a waterproof box. remove the old heater, make sure you remove the old rubber sealing ring from the tank too.
Put the new sealing ring on the new heater, manoeuver it in to the tank, making sure the bent part is as low as possible, it only has the option of being in two possible positions due to the fixed mounting bolts. Replace the nuts on their bolts and tighten evenly until a tight fit, but do not overtighten. then fit the attaced thermostat to its fixed locating bolts. cut the black wire to suitable length to allow connecting to the terminal block you have just installed on the other cable, make sure you have the colours matching.seal the box. Thats it,,,just fill with water to check sealing is ok, tighten if needed, and the job is done.Fold back the cardboard into its normal place, replace anything you moved to gain access.
The reason for cutting the wire is normally the elements come without plugs, and you need a special tool to fit said plugs!!
If you are lucky enough to get one pre fitted, use thin string on the old plug and pull it through withthe plug, so you can pull the new plug back the same way.
Hope this helps.
Status comes off very easily - just unscrew but don't loose the two grub screws (Allen key head) around the base. Take the connector which plugs into the booster off, and pull the lead through from the outside. Stutus should supply a plastic cap to fit over the hole, but if they haven't you will find that the standard cap from Boots 100 Aspirin table container or similar (the child proof type) will be a good fit over the upstandinging boss. Just put a good bead of silicone inside it and pop it on. It will come off easily when you need to refit the status.
Brittany sometimes check heights, and my Coachman is above 2.6m with the status but below 2.6 without it and considerable cheaper as a result.
Yes its easy to remove as per the other comments. When you pull the ariel lead from inside the van tie a piece of string to it. It might not be that easy to rethread the lead.
Steve
Steve
Plastic stopper from a bottle of plonk is a perfect fit in the Status aerial hole.
