Steaming up window?
Apr 9, 2006
206
One of my front opening window is steaming up i pressume this is because water has got in if so how does water get in and how do i dry it out, noticed some bungs in the top of window?
936
Andrew, it is not uncommon to have moisture between the widow panels, they are not sealed units as domestic ones are.
The bungs are for precisely this happening, ease them out carefully and leave out , on a dry sunny day until the moisture has evaporated, then refit the bungs.
Jun 23, 2008
9
Legs....I was wondering what you were doing up at that time of night !
Hi
We have a Ace Globtrotter.And we have the same problem,regarding the front window.And our window,has been steamed up for awhile,regardless if we had sex or not.
But i can,t find a bung,to let the window dry out.
Kind regards
Chris & Tonina
Apr 15, 2005
103
What is the best thing to ease the little window bungs out with. Is there a special tool? I struggled with ordinary pliers. I just didn't want to damage the bungs.
Rob
Apr 15, 2005
103
The bungs are usually at the top corner of your windows on the inside. They are not always obvious as they are clear plastic. Have a close look , I hope you find them.
Hope you get sorted
Rob
