Hello,
Do you need to sterilize the internal pipes before using the water works?
I bought a bottle of Milton & was trying to think what I have to sterilize.
Would you place the solution in the fresh water container with fresh water & run the taps to get the Milton through the system until empty?
If I did this & ran the hot water tap as well, then obviously this would then go into the hot water tank, is this ok if also drained?
Thanks in advance
Thanks in advance
