Submersible pump
Mar 9, 2006
9
Is it possible to upgrade you submersible pump to a more powerful one as i need more pressure for my shower?
I was thinking of getting a reich 19 L/min but i don't know if it would work. I currently have a carver thames water pump and hose
3,564
Hello Ian,
The simple answer is yes, however life isn't always that simple. The flow capacity of a pump is not always an indicator of the pressure it will develop, and the pressure in the caravan may be limited by the method used to control the pump.
If you have a pressure switched system, then a 'bigger' pump is unlikely to make much difference, as the operating point of the pressure switch limits the maximum pressure developed. You can try adjusting the pressure switch, and you may find that your existing pump is actually all you need.
The other method of controlling the pump, is by switched taps. Basically all the taps in the caravan have a micro-switch buried in them, and as soon as you turn the faucet the pump begins to run. In this system a more powerful pump may make a difference, but the limiting factor is usually the bore of the pipe-work and the internal openings in the taps.
Another consideration will be the amount of water you use. Your water heater will only have a limited volume of hot water, and a higher pressure/flow will use it up more quickly. Also you will need to fill your supply tank, and empty your waste more often.
Caravan showers were never designed to be perfect replacements for a domestic system, but they do at least allow of an element of freedom from site washroom blocks.
Mar 11, 2007
585
Ian
I hope this is not a silly response ....But....A mate who uses his van shower regually has told me to simply replace the screw on shower head to one with a finer or an adjustable spray.
It worked for him
