Sunglasses
What did an upgrade kit consist of? At one time Cibie headlights started to become after market accessories.
A whole light unit replacement, reflector and bonded on front lens with H4 logo a moulded on feature; VW Bettle, can't remember now if it was our 6 volt one or one of the newer 12 volt cars.
I do remember how impressed we were with the lighting improvement the conversion made.
I recall fitting Wipac Quadoptics to replace the Lucas sealed beam units on a couple of cars - huge improvement - one Escort received the full boy racer treatment with 4x Cibie Oscars !
It is a very personal thing. My wife suffers from the same problem. She is dazzled by practically all oncoming traffic fitted with anything more light intensive than halogen headlamps. On the other hand, I don't have an issue when confronted by exactly the same situation. Only in extreme cases do I find that I have to concentrate more on looking in the direction of the nearside until the oncoming vehicle has passed, basically filtering the bright light on the offside out. I can't say that it's ever a big problem for me.
In the 1980’s a friend had a Lancia Beta with twin headlights. Where I worked we could get servicing done on our cars. He had his car in the workshop for the day. During this time many of us got together to ‘update ‘his headlights. New units were built incorporating candles.
He was not impressed.
Of course the other issue not mentioned is the driver with the extremely brights lights reflecting in your rear mirrors. Many cars have the internal rear mirrors that deflects the light straight away, but others you have to manually switch over.
If it is really Sunny in the daytime I wear prescriptions Varifocal Sunglasses whilst driving, but all other times the antiglare ones.
I complained of this issue a couple of eye tests ago, and was advised to consider Zeiss coated lenses with a very minor distance prescription. They are transformational, in that they significantly reduce the starburst effect -which, by the way, can be early signs of cataracts- and also reduce the glare.
My current specs are supposed to be anti glare, but do not seem to be very effective? Maybe pay the extra for a quality pair with decent anti glare. Hardly ever drive at night so mainly for those really sunny days when they sometimes occur.
Some metal frames can pick up light from above or the sides and throw glare across the lens even if the lens has an anti glare coating. I had a pair of frames replaced for this reason by my opticians. It was annoying in sunlight, but overhead light glare could be reduced by wearing a hat. At night though the frames could refract light from vehicles towards the side of my line of vision. I was even considering going to a plastic frame but the replacement metal frames resolved it.
I got bored paying for expensive coatings so I could drive at night and after Xmas treated myself to cataract removal in both eyes.
Transformational I can now see again at distance and only really need glasses for using the PC and reading.
My wife had two cataracts removed back in 2014 prior to a trip to India and the difference in her vision was nothing short of amazing. She has only recently had to have a distance prescription for glasses. Hope yours lasts as long as her has done.
Almost an exactly similar result; had mine done in 2015 and have only within the last 5 weeks gone back to distance glasses. This mainly to ease eye strain, as I was great every morning but started struggling in the evenings. Going back to glasses no issue all day.
The original ops were transformational, had by the time I needed the ops basically forgotten how strongly coloured much of the outside is; like in "Technicolor". Had worn glasses for decades up to the ops, then none.
Something for me to look forward to as I have worn glasses since I was 26 years, but fortunately only the slightest hint of a cataract one eye. But to be able to use my binoculars with out glasses would be absolutely great., but no rush.
I'm still wearing "varifocals" even after the op.
Distance prescription is 0 so plain glass then getting stronger down to my reading prescription at the bottom. Transition lenses so sunglasses when needed.
Why?
Because I've just spent 2 months switching between sunglasses, PC glasses and reading glasses and it's a complete PitA. I never had the right pair with me or if I did I had reading glasses on the end of my snout and sun glasses perched on my head.Far easier just to wear one pair all the time as I have done for years.
Binoculars and telescopes can be used without glasses even by people who normally wear them - the focus control will adjust to a slightly different point and effectively correct your vision in the same way that glasses do - apart from the very cheapest binoculars, they all can adjust the focus on one eyepiece to reflect any difference in prescription from left to right, in addition to their main focus control which alters both eyepieces.
By taking your glasses lens out of the sequence, you should get a marginally better view as there's less light loss.
Why?
I still wear varifocals while I'm driving but not any other time - my distance prescription is only 0.25 but the reading prescription ensures I can see the satnav clearly.
I wear zero prescription sunglasses with polarising lenses.
My binoculars are Zeiss 10x40 but they cannot be adjusted to cater for the fact that I have prisms in my glasses prescription. So it’s not possible to take my glasses out of the sequence.
Glad it's not just me 😎
As did my wife a few years after yours. She wore glasses or contacts all her life. But now has good short and long distance vision.
In my case pre the ops they did tests and ordered specific lens to suit my eyes, so basically they start a fresh over the "original" and if they get it right you should not need glasses. In my case and it appears others they seem to be getting that bit right.
However as time marches on things change, now 10 years on I benefit from using glasses, as I said to relieve having to strain my eyes , albeit I had been doing that subconsciously.
Do they do cataract removal on the NHS and if so what to they do as apparently I have cataracts in my right eye. Apparently the operation can cost about £5000?
Yes they do cataracts on the NHS. My wife had hers done that way six weeks apart. But in recent times some trusts have decided to only do one eye. Then as he second eye gets worse they may do that one later. Yet one trust is now doing two eyes at the same appointment, with outcomes being very good. It’s a post code lottery.
A friend of mine who no longer drives due to glaucoma had a cataract removed privately and that cost £6000, but it’s giving him some more time even with diminished vision.
Privately it was £3450 for each eye, that was with the cheaper lens that just sorts the distance vision, £4450 if I wanted the all singing and dancing lens that corrected both for distance and reading.
My eyes were not bad enough for the NHS to even consider them, my neighbor who had been referred by the NHS waited nine months before she gave up and decided to go private.
The clinic I used does both NHS and private and it was said whilst I was there that the NHS lenses are not of the same quality that the ones used privately 😱
