super type pitch requirements
May 15, 2006
53
just bought a 1996 fleetwood challenger 1500-2eb 2 birth model. booked a super type pitch for the first time. my van appears to still have the old 3/4" dia outlet pipes fitted, the water pump is a "carver" type that drops into an aqu roll. Could anyone advise what equipment I need to purhase to enable me to utilise the facilities offered on a "super" pitch. Any info/advice would be appreciated.
Jul 12, 2005
1,896
We use a 40L aquaroll that has the hole in the side and the official aquaroll attachment that fills it from the tap. as for the waste, just get a length of pipe from the local dealer. Tell them what its for and they will help
Steve
Aug 29, 2006
291
We use the same as Steve.
It is alot cheaper to make your own attachment. You will need a spare aquaroll cap and a mini ballcock, we got ours from Wickes, you will need to take off the part with the plastic tube attached to get it into the aquaroll. make hole in cap so the pipe fits through and there you have it very easy. No more trips to the tap.
Will
May 15, 2006
53
Will
Thanks to Will and Steve for the info. Will have a go at what you advise regards
