I was interested to read a thread about using the car or a generator to keep the leisure battery charged during a week ath the Great Dorset Steam Fair.
Now I am also going to the GDSF and we are taking the caravan this year, having previously used a tent.
We were hoping, really, that the leisure battery would last a week, without charging, and would like to har other's views.
The battery is 110AH. I have tried, without success, to find out how power hungry the various things in the 'van are.
Most things will be run on gas - in fact the only things I can think of that will use the battery will be the lights, the water pump and the toilet flush.
lights - lets assume we use 2 spotlights for an hour each night. How much power does a spotlight use? About 15W? If that is the case they will draw 17.5A over the course of a week.
Water pump - If someone knows the wattage of the water pump (standard submersible type), or how many amps it draws, together with the rate of flow, perhaps you could let me know - I reckon it will pump around 200L over the week and with the power consumption figures and flow I can get an idea how much of our battery will be going towards pumping water.
Flush - I reckon this must use less power than the water pump as the water is a lower pressure. If anyone has the power and flow figures for this I would be grateful (ordinary Thetford swivel toilet). I don't know the capacity of the flush tank - for some reason I think it is about 15-20L, so let's assume it will pump 50L of pink in a week!
Now I know my battery will allow a discharge rate of 110 amps for an hour or 1 amp for 110 hours. I also know that, fully charged, it should read 12.6 volts and at 12.0 volts it is considered flat but how do the volts and amps connect?
If I have drawn, say, 11 amps for 10 hours my battery, presumably, will be disharged. Does that mean it will read 0 volts? 12 Volts? Or something else?
In other words, if I discharge it to that extent will it be dead - never to be revived? Or have I got it all wrong?
If I'm on the right lines then it looks, to me, that my battery has a pretty good chance of lasting the week.
Please let me hear your views.
