Taps not working
Further to my earlier post we have a new pump. There is power to the socket where the pump plugs in but no-one of the taps or shower activate the pump. All fuses checked
Any ideas ?
If you have 12v to the pump you should hear it running its trying to pump water so could be a clogged filter on cold supply from pump to the first outlet /tap, could also be a faulty non return valve between the pump and first outlet/tap
Gra
I had a problem where the cold water would run but not the hot. It turned out to be the non-return valve feeding into the heater tank had seized.
It could be the pressure switch, this should be just inside the caravan where the water enters and has a knurled knob on top. You simply turn this until you hear the water running if that is the problem. It is a bit trial and error.
If this is a new pump then a clogged filter should not be the answer, but shaking it up and down a bit in the water could clear any air lock.
