If they want to run the fridge on Mains electricity it must be hooked up...... it doesn't work on the battery and will only work using the cars electrical system when the caravan is connected to the car, the engine is running and....providing the wiring allows for this.It's not hooked up it's in their drive
It occurred to me that we all make easy comments about these issues, but from a standpoint often of years of experience. While the desire to help is a given, few newbies will realise just how complex a caravan can be with tricky braking gear, multiple fuel sources and water systems etc, So lets make sure we keep the advice in plain terms for the newby, otherwise they will be overwelmed, as a look at many forum comments will confirm. Regards to you all.
BryanTheSnail said:It occurred to me that we all make easy comments about these issues, but from a standpoint often of years of experience. While the desire to help is a given, few newbies will realise just how complex a caravan can be with tricky braking gear, multiple fuel sources and water systems etc, So lets make sure we keep the advice in plain terms for the newby, otherwise they will be overwelmed, as a look at many forum comments will confirm. Regards to you all.
Craigyoung said:Nothing to do with the nose weight . . . .?! 😗
EH52ARH said:I can possibly se where Bryan is coming from, a simple reply such as "Is the caravan hooked up" to one person that would meaan hooked up to the car and another hooked up to the mains.
