Technical
Hi
Awning Rail
I'm looking for a tool to create an opening in the awning rail for threading the awning bead in the vertical section away from the end. Can anyone suggest a supplier
Mac
The alluminium used by most manufacturers is of the soft pliable type so it bends around the curves.
I would not play around with it, you may regret it.
May be a dealers workshop could help.
I borrowed the tool from my dealer
Its just 2 strips of steel about 2 in wide welded together with a gap that is the thickness of the awning rail
It has a handle and you just place it in the groove and lever the rail open
It depends on the rail
Bailey seem to use thicker stiffer alloy
I have done one on a Swift with a length of 2in X 1in timber a foot or so long
Place the narrow end on the outer section of the rail in the slot and give a sharp tap with a hammer
