That Green thing
Sep 24, 2008
919
238
19,135
This morning went out to caravan to hook up with car to make sure all light are working. After about an hour still trying to connect plug. I used the "Green " cap to align the plug but it refused to go in and turn. Eventually got it done but more a fluke thing. Any one know what could be stopping it ?.
Jan 31, 2018
1,783
850
Is the outer of the connector able to move-the green thing simply makes the middle bit rotate round the outer-or vice versa would be a better description-issomething in the jamming it-muck or grit? Or has the plastic been distorted?
Jan 19, 2002
1,504
421
Also check that none of the pins are bent or out of line especially if the initially obstinacy led to so many attempts to connect.
Oct 3, 2013
890
90
18,935
Hello,
I use the "green thing" - mine is blue, each time I disconnect the van from the car.I've come to the conclusion that the pins can come out of line depending on how violently you twist the plug when disconnecting.
Usually jiggling the "green thing" about makes it connect with the plug ok ready for the next time you connect to the car.
Reactions: Robert_374373903
1,793
I had a problem using it and needed help. It does seem before realigning the lug on the plug went in to the left and it now goes in at the top. Not sure how that happened but that was it.
