Hello,
Hello! I am Ciprian from Romania and I own an Abbey Vogue GTS 214 caravan, from 1998, with a Carver heating system. I am facing the following problem. When I connect the heating to 220V, and from the control panel it is set to minimum, and the speed is on auto, my resettable thermocouple is triggered. I mention that I measured the trigger temperature and it is correct 232 degrees Celsius, respectively 450 Fahrenheit. I also measured the thermistor (temperature sensor) and it indicated 28.8 when cold. Can a colleague help me with some advice? Or can someone tell me what the capacity of the thermistor is? Maybe it is defective and needs to be replaced. Thank you!
