Thetford C250 Toilet
5,124
Is it any good WC?
An electrical contact spray cleans and etches the contact surfaces restoring a good electric flow. Mine failed two years ago and is fine.However once a year I remove the fuse from its holder apply contact spray. Let it dry and put in a new fuse.
936
Why would anyone buy WD Contact Spray at £6.63 when there are numerous other contact cleaners at prices from £3.99 (Halfords), for example.!!
5,124
WoodlandsCamper said:
Dustydog said:
Is it any good WC?
No idea, I've never used it. I just happened to see the advert. ;)
Oh dear Sir WC..
I can't believe a Woos ie of your calibre and a past King can suggest something you've never used. You naughty Woosie
Feb 3, 2008
3,790
Dustydog said:
Is it any good WC?
Oh dear Sir WC..
Not guilty m'lord, I didn't suggest it. I only made reference to it, therefore I plead the 1st, 2nd and any other excuse I can. :p
Apr 7, 2008
4,909
When I put our van on the season pitch last February i sprayed some silicone spray into the 13 pin plug & socket. When i came to plug them back together in September to check the lights etc i was getting all sorts of faults as i had forgotten about coating them both with silicone spray as neither were going to be used for quite a while, i had a tin of WD40 contact cleaner in the van and after a good spray into the plug & the socket and re plugged in everything worked as it should have. .... so it worked ok for me ...
