thetford cassette toilet lost vacuum !
Jan 28, 2007
55
hello to all , while we were away recently , the toilet lost most of its vacuum to pump the water around the bowl, has anybody else had a similar problem, is their some kind of diaphram inside i wonder , help please glen
2,556
I apologize if you've already checked this - is there any water in the flush tank as that's exactly how it goes when it runs out.
936
Glen it depends what toilet you have fitted.
If it is electric flush , apart from running out of flush water, it may be the pump, or just the connection.
If it is a manual flush , it will either be the bellows, or the O ring on the later model pump.if you can let us know the model, more info will be available.
Jan 28, 2007
55
hi , thanks for your reply, its a swivel bowl type and its in a 2003 van, and in reference to the above answer ....yes there is water in it !!!!! thanks to all
