Thetford gas oven.
Apr 27, 2025
27
8
35
Hi All!
My Thetford Gas oven in my Baileys caravan has (half) stopped working. Two out of the three hobs will light but the 3rd one and the oven/grill have all stopped working. It is the two hobs with buttons on the left hand side that work.. and the hob button and grill/oven button on the right that have stopped.. what could be possible problems? I changed the gas bottle for the 2nd time ever the other day. The oven did light again after that once but hasn't worked since. I presume it can't be a problem with the gas coming through as the two others work!
Apr 27, 2025
27
8
35
Sounds though you have a problem with the igniters on these if you can hear and smell gas coming through
I can't actually hear or smell the gas .. Im having to wait till monday till someon can bring me a match/lighter to test it.. but it doesnt seem to be coming throught . but is obviously coming through for the other two hobs and the igniters working for them so its very strange!
Sep 4, 2011
789
489
19,135
Is there anything stopping the taps when turned being pressed right in to release the gas. Have they gone stiff. If so pull knobs off and give spindle a light spray of WD40.
Reactions: Daxrank
Apr 27, 2025
27
8
35
Maybe in his youth his parents didn't allow him access to matches etc. 🤔
Im a she , but your right i could use a twig but its been raining solid for 2 days here so not much chance of finding a dry one, but that is one idea. I have paper etc inside too but i HATE fire and didnt fancy starting one on something fast burning like that because knowing my luck the caravan will set alight :ROFLMAO:
Apr 27, 2025
27
8
35
I have had a play around with the knobs and they seem to be turning ok...it does sound like gas is coming out of the hob but unsure with the oven. If it was the ignighter not working how do i fix that? It is the same igniter button for all of them so is it strange half of it is working and the other isnt? Thanks for your help!
Feb 13, 2024
1,588
1,020
2,935
Sorted 👌
Reactions: Mel
4,473
DO NOT USE NAKED FLAMES TO TEST FOR GAS.
If the hob and oven are not working properly, as you describe, it sound like blocked injectors or possibly ignitor issues. I have to advise that other than general cleaning (where you do not need any tools to remove parts) unless you are fully competent at gas work it is necessary to call in service technician to service the cooker.
5,585
I have had a semi blocked jet before on the grille. The gas pipe leading to it rusted allowing debris to block the miniscule tiny jet stopping the gas flow. It meant total removal of the whole cooker, disconnecting the gas and electric supply.
If you are NOT competent or qualified to go this far then I am afraid you need to call in an expert engineer, say an AWS engineer https://www.approvedworkshops.co.uk/find-approved-workshop.
Reactions: Daxrank
Apr 27, 2025
27
8
35
Thankyou for the link.. that is really helpful!! its a bit of a worry to know who to go too!! So i really do appreciate that webpage!
I got a proper oven lighter and the oven and grill both work ok if lighted by hand. BUT the one broken hob will not light properly. It will catch a spark but then puts out a tall proper flame which is quiet scary.. the other two hobs still work as normal and can be light by the button.
So at the moment i am just living without that extra hob and lighting the oven/grill by hand and all is ok for now. But i will definitly get it looked at by a professional in the future!
Reactions: ProfJohnL
Apr 23, 2024
671
536
1,135
Also you can search www.mobilecaravanengineers.co.uk to look for an independant mobile engineer affiliated to the MCEA in your area.
A tall flame indicates a regulator problem or debris underneath the mantle preventing proper mixing of gas and air before it exits the mantle nozzles. The ignitor unit at the back of the oven may also be faulty( damaged lead to one or more of the burners) and oil contamination in the gas lines can give curious results. I am always surprised by how much debris can get into area underneath the mantles as they are screwed on , unlike domestic hobs were they can be lifted off for cleaning . I have also seen water in them which again can give rise to large yellow flames and a failure of the igniter to light the gas.
Reactions: Daxrank
4,473
Just like domestic cookers, caravan hobs and ovens do need some maintenance by their owners. You should follow the advice and instructions in the appliance's user manual about how to deep clean. you should not need any tools to complete such maintenance.
As a general rule for gas appliance's, I believe if you encounter something that needs tools to disassemble for cleaning or any other maintenance activity that's the point where it should only be done by a fully qualified and authorised fitter.
