Thetford N112 fridge - code 12 error
Aug 27, 2024
10
Am looking for advice on whether to repair or to replace this fridge in our caravan ? In Lancashire and struggling to find repair agent any help appreciated please
Seems to be an wiring / circuit board fault from my limited knowledge but need local repairer
Sep 4, 2011
404
198
18,735
You might find a refurbished board on EBay if it is definitly that but often the control module is the fault if the panel lights up as new parts are obsolete Have you checked there is at least 12 volt or higher voltage at connector back of the fridge
10
All I really know is the display panel flashes error code 12 - I thought might be circuit board issue when trying to google error code 12 so really not sure but thank you
Sep 4, 2011
404
198
18,735
What voltage is the leisure battery reading. If you are on a mains hook up should be 13,6 volts If not on hookup charged battery should read 12,6 volts. If voltage low could be the problem but best checked is back of fridge voltage
Nov 30, 2022
1,821
1,680
2,935
You will need to be sitting down when you check the cost of a new fridge! You will need to rip out an internal organ, and thats just for the deposit :eek:
2,054
If you go on the AWS website you will be able to find caravan workshops near you. I did a search 30 miles around Lancaster and found quite a few.
Good luck. Hope someone can help within budget
Reactions: Hazel66
Aug 27, 2024
10
I will check voltage tomorrow when we go up to storage and let you know , thanks
oh I know I do to want to spend that at all 😳
thank you will contact them
