Yes, grill lights fine, and it’s all the same equipment. Just seems to be oven not sparking up.
12v supply is fine.
I’m going to remove oven from cabinet and have a look for a loose wire… if not that, I’ll order a new sparky thingy… (thermocouple?)
Hello cglittle,
The thermocouple is not the ignitor. The thermocouple is parts of a safety system called a Flame Failure Device (FFD) system and if the flame goes out it
will automatically shut the gas flow off after a few seconds.
The ignition system will use another electrode made of ceramic tube with a length of wire sticking out of it. it is designed to sit about 3 to 5mm above the burner, and when the ignitor is activated , the energy will produce a high voltage spark that will jump from the probe across a port on the burner bar to ignite the gas/air mixture.
The flame should be an transparent blue colour of an even height along the length of the burner. Where the ignitor and the thermocouple probes touch the flame it might turn orange.
If the flame is a solid yellow or is producing soot it means the its not burning correctly. This might prevent it from lighting, and it certainly needs checking out. It might just need the burner cleaning, and instructions for this should be found in the users handbook.
Bear in mind this is a gas appliance with an open flame that burns inside the living space of the caravan. If its not burning correctly it will be producing Carbon Monoxide gas which is seriously harmful.
For the safety of you and your family, I strongly recommend you arrange to get the cooker serviced by a member of the
Approved Workshop Scheme (AWS) who will know how to check the function and safety of the appliance.
Postscript. Mr Plod's suggestion of a gas lighter stick would be simple solution, provided the flame on the burner is blue, Low cost potion and pretty reliable
