Thetford porta potti C2
Aug 23, 2014
Can anyone help ? I have a C2 that wont flush and have checked everything I can- fuse, hidden micro switches etc but still no power. If it has an isolator switch I cant find it, we have a Bailey Buccaneer (1994), everything on it has hardly been used but that can cause problems I know.
937
Have you checked the pump ? and that the impeller rotates?
When you operate the flush, do the lights dim at all?
Aug 23, 2014
I have replaced the pump but don't appear to be getting any power to it. Have checked micro switches which both appear to click when manually operated and have refilled main system to switch power on for main water tank in case it was in some way reliant on the power from that system. Lights no not dim because no power so unless there is something else to check I will test power to connector near where the fuse is fitted.
Aug 23, 2014
Soughted it . It was the micro switches. Although they clicked sweetly they were poorly and when doused in WD40 came back to life. When you have to remove the control box just pray that you have a left handed fix because otherwise you have to use mirrors and torches to be able to get at the fixing screws. Many curses there ! But now we have flushed with success.Cheers, now onto the boiler !
