Toilet
Feb 27, 2023
10
Hi
Just got back from our van and the toilet as stopped working can any one tell me if the fuse is outside in the toilet compartment
It's a swift lifestyle 6fb 2017
9,232
Hi
It might be the flush touch pad that’s at fault. They are easy to remove and you can then clean the pcb contacts with electrical contact cleaner. I never ever did find my fuse which was supposed to be in the external cassette/ flush tank locker. The other strange thing about mine is that you could flush the toilet even when all the electrics were switched off. I suspect that the previous owner may have dabbled.
Reactions: John e
4,641
As OC , no fuse in the toilet cassette locker, but luckily never had a problem 2013 Coachman. 560.
Jun 11, 2012
1,533
33
19,685
The C250 has been a problem posted here several times.As you can see in the video the fuse is well hidden , The reed switch is another part that fails plus as you see on flush button the micro switch in the board can be a problem too_Our van is now 13 years old and its first 10years we had replace the bord housing the flush button. If you are worried about the casette full light not working then there is an easy fix.Get your service engineer or yourself and fit a small toggle switch to the printed circuit board and pick up the live wire from the loom and connect to switch.The cost will be cheaper than having to replace board. I hope this helps.
