After reading the recent thread where the wheel came off of a caravan and the other wheel nuts were lose I decide to delve a little deeper on what advice is given. And like a lot of things caravan it isn't as straight forward as the advise given to car drivers.
Firstly I looked at all of my caravans previous service sheets. All were carried out by NCC Approved workshops. None showed that either two workshop signatories were involved in the torquing of the wheels, and none showed the Customer being a witness or even signing the worksheets. All however did show the correct torque in the required recording box. Only one from a Swift Main Dealer had any information regarding post servicing checking of the wheel torque. That recommended a recheck after 25 miles approximately, whereas the caravan handbook recommends 15 miles.
Caravan and Motorhome Club recommends a re-check after 20-30 miles or 20-30 minutes driving.
Camping and Caravan Club recommends 50 miles after service.
Wheel Specialist Ltd recommends 30-50 miles.
NCC via an Alko guidance sheet recommends recheck after 20 miles, although looking at the Alko guidance sheets which show an alloy wheel being torqued to 88Nm that should be changed to recommend caravan manufactures specified torque as 88Nm tends to be for steel wheels.
My Swift Sprite Owners Handbook recommends 15 miles approx and the Main Dealer 25 miles.
So what do I conclude from the above? Well a recheck at 25 miles would seem to be a reasonable distance, but that would be going against my own Owners Handbook.
There is widespread agreement within the various sources that I have looked at that checking the wheel torque before each journey is recommended . But WSL advise a further recheck after 30-50 miles into the trip. I must admit I don't do that. But what constitutes a journey/trip? Does 250 miles to Penrith, and after an overnight stop a further 250 miles into the Highlands constitute one or two journeys? Is the return trip part of the overall journey or a new journey? recently after a relatively short trip to Shropshire I did check my wheel torques for the return trip as the roads going were so dire and not just on the near side that I guess I just wanted a bit of comfort. My handbook says that after the post service recheck, further checks should be done regularly.
Then what is a torque check? There are some who advise just using the torque wrench and smoothly applying leverage until it clicks. Whist others advise to loosen the wheel bolt(s) and then retorque. But its not stated whether one should loosen bolts singularly and re torque, or loosen the complete set and retorque.
My own practice is:
1. Ensure that I have seen wheel bolts torqued up at service centre, or do it myself as part of pre departure check. Recheck within 25 miles after service, or wheel replacement.
2. Check wheel torque prior to each journey which normally is outbound and inbound unless fora main holiday where distances are longer when I check outbound and inbound. Shropshire being the exception!
3. Retorque but just applying the torque wrench to the already torqued wheels. I don't loosen bolts/nuts.
4. Give the car wheels a cursory glance for completeness ( A TIC comment)
I bet Ben Hur didnt have such issues when he visited the Forum prior to his trip to the Colliseum :evil:
http://www.caravantimes.co.uk/video/parts/wsl/video-wheel-solutions-explains-how-to-torque-your-caravan-wheel-bolts-$21381952.htm
My own practice is:
