- Jul 8, 2008
- 1
- 0
- 0
After encountering overheating problems I fitted the additional cooling radiator as recommended problem solved !
About 18 months later,while towing I lost all transmission,one of the rubber pipes attached to the additional radiator having fallen off, the contents of the automatic gearbox emptied out onto the road. Upon investigation I could very easily slide the pipe on or off the radiator fitting even though it should have been held in place by a metal collar crimped over the pipe .I replaced both collars with jubilee clips.
If anyone has one of these radiators fitted a quick check on the tightness of the pipes could save a lot of time and trouble later.
I did inform the manufacturer and sent them the fittings but have not heard anymore from them
