Tow Ball Spacer
Nov 19, 2006
246
I want to bring the towball out a bit further on my towbar so the Alko stablizer hitch is clear.It is an Alko towball. Is it okay to use a 13mm spacer. I tow a T@B - 800 kgs.
776
lutzschelisch.wix.com
In view of the fact that you are towing only a light caravan, I personally would not have any reservations with a 13mm spacer so long as it's made of suitable material. I'd make sure that high tensile bolts are used, though.
44
19,185
I have no issues with an alloy spacer, I use a 15mm cast one myself so the Alko hitch does not catch the bumper protector.
Jul 15, 2005
2,175
Hi,
I'm with Lutz on this one - but my concern is different - unprotected aluminium in contact with steel is prone to galvanic corrosion.
Two dissimilar metals in tight contact + water = shorted out battery
And it's much worse if the water is a bit salty - like in winter.
If you are happy with the alloy spacer from a strength basis, make sure that the aluminium is very well protected (paint) from direct contact with the tow-bar, tow-ball and the through bolts.
Steel may / will go rusty but it won't corrode as quickly as an aluminium / steel pair can.
Robert
This is what Witter say fot the Freelander
EC Type Approved: Yes Tow Ball: Flange 2 Bolt
EC Type No: 01-0735 S Value (kg): 140
Max Towing Capacity (kg): D Value (kN): 10.00
Max Coupling Packer (mm): 25 Cycle Carrier: ZX108 or ZX109
Max Drop Plate Size (mm): 0 Spare Wheel Location:
Nov 19, 2006
246
Many thanks to all who responded. Think I will get a steel spacer.
