Tow Ball
18,685
Hi. I have had a Brink BMU detatchable tow bar fitted. The surface of the tow ball (and all the way down the detached bit's length) has a black coating. It doesn't look like paint to me maybe it is. however, does anyone know if the tow ball needs to be made a silver colour before attaching the Alko AKS 3004 hitch?
Thanks.
View: https://www.youtube.com/watch?v=xx7ItIyqIuA
Jul 30, 2007
1,461
404
19,435
Yes....all the black paint has to come off the ball before you hitch up otherwise it will contaminate the pads.
Emery paper usually does the trick along with maybe a wire brush.
I always use a spray of brake cleaner on the ball and give it a wipe each time before I hitch up as well.
18,685
Thank you for the fast reply. Will carry that out now.
May 24, 2014
3,687
765
I normally use the wire brush to break the surface but rather than emery i use wire wool. Indeed i always carry wire wool and give the towball a tickle before each journey.
Reactions: Daventura
Mar 29, 2021
277
146
735
On removing the black paint, I use a wire cup attached to a small angle grinder, brings it off in seconds, tried manual labour, too much effort 😁
1,688
532
Makes you wonder why they paint the whole thing at the manufacture stage? Also for Dave assuming you have a hitch head stabiliser, ensure the ball is kept grease-free (for example if you tow another trailer to the tip like me!) so I too use a brake cleaner spray before towing the caravan, occasionally give a rub with fine grade wet and dry, and keep a plastic cap on the ball (fixed swan neck) when unhitched.
18,685
Thanks for the advice.
2,466
Mine works exactly same way .
Feb 23, 2018
914
87
18,935
Put some tape around the neck just under the ball when removing the paint as its easy to catch it when you don't need to.
Makes you wonder why they paint the whole thing at the manufacture stage? ...
I only towed a caravan with a 'wet' hitch for some time, so didn't need to remove the paint from my towball. Stops it from rusting that way.
+1 for Brake cleaner. Give it a clean each time you use it. I also clean the hitch/stabiliser pads each trip to prevent squeaking/grinding noises.
Not seen anyone else mention this, but after some time in storage, I found my detachable had rusted quite badly; so I now keep it covered in grease when not using it.
