- Jul 19, 2016
- 4
- 0
- 0
I have just changed car and had a main dealer (Ford) fitted removable tow bar with 13pin plug. I did this because the ESP, Parking sensors & fog lights needed programming by a main dealer. My old car had12N & 12S plugs. When I plugged my new car into the caravan all lights work and it powers the interior lights and fridge until I start the car, then nothing works inside the van (even with the rocker switch on "car"). I understand this maybe a safety feature once I am driving but shouldn't my fridge still "light up inside" to show its working when towing?
I got the Ford dealer to recheck the wiring and pin 9 & 10 are both permanent 12v, but I believe only 9 should be and 10 should be ignition controlled. This is how Fords say the towing module works and I don't have a problem with that but could the two permanent feeds be stopping the fridge working with the engine running? Or do I need to make pin 10 ignition controlled?
Help, I am off to France tomorrow and worry about the fridge working when I am towing!
