Apr 2, 2024
10
515
Hi, we have just got a new van after many years and need a tow bar. Has anyone used Towbar2u? They ask for full payment up front which is quite a lot. Thanks
4,253
I see they have a very good reviews, and use local fitters to your area.
The only problem I can see is the quality of your local fitter. If you can research your local area for that fitter and see their reviews.
Jan 19, 2002
1,690
534
I think google ‘towbar fitting near me’ and find some prices on line - here ‘towbar2u’ and Halfords come up in a long list. Likely you will find a huge variety of prices for exactly the same manufacture towbar.
Have you decided on the type of bar you require? witter website gives good descriptions. I’m sure others will concur with the advice of having dedicated wiring kit fitted for your specific vehicle.
Nov 30, 2022
1,856
1,704
2,935
The actual fitting of a towbar is not difficult job and is pretty much a DIY job. What ISNT an easy job however is getting the electrics right (decent sized cable feeding the caravans 12v supply for the fridge etc) and any ECU reprogramming that might be required.
4,141
IF you were to attempt to do a DIY fitting, you must still use conforming parts as approved by the vehicle manufacturer. NOt only to sort out the electrics that Plod mentions, but also to ensure the assembly picks up support from the correct parts of the tow vehicles construction. You must also use the approved nuts and bolts and use a torque wrench to ensure all fixings are correctly loaded.
Nov 30, 2022
1,856
1,704
2,935
I wasn't suggesting the OP fits his towbar, just trying to show that is the "easy" part when compared to the electrics.
Aug 12, 2023
648
296
1,135
If car is still under factory warranty make sure any aftermarket towbar and installer is approved by vehicle manufacturer.
1,818
We have a Tow Trust one fitted at a proper workshop. I do worry about these fitter who do t in your drive cutting corners if the weather is bad.
4,253
On a previous Santa Fe, I had a mobile fitter, to fit a Towbar and electrics for me whilst I was at work. During installation he asked my wife if I had certain tools, as he didn't have them. She said NO, she didn't have the keys to my tool box's. I have Snap on tools with the sticker "Please don't ask to borrow my tools"
8,529
Towbar2u fitted a Tow Trust which I think is one of the best and did a superb job.
I’ve always used Witter or Brink, both fixed and detachable and never had a problems with the towbars or electrics. What is about Tow Trust that makes it one of the best?
Apr 2, 2024
10
515
Apparently, Witter is not Witter anymore as someone bought the name, not the quality standard. Tow Trust is committed to quality products and making the best they can. At least that's my understanding.
584
Our previous Santa Fe, bought used , came with a Witter towbar which we had to hav eraised as it had dropped, so when we had to fit a towbar to new Santa Fe, we chose Tow Trust after looking at several makes, I think from memory the TT bar had higher weight rating, had no problems with it in nearly 4 years it is a fixed one.,
8,529
Witter was taken over by a US company as were Westfalia. Witter have a design facility in Deeside manufacture some products there too. Their tow bars are designed and tested to meet the various directives and are of course type approved for specific vehicle fitments. Any towbar fitted in UK will be supplied from their Deeside facility, along with Westfalia products. The technical customer support is based their too.
3,243
Given that ALL towbars sold in EU/UK have to be designed, test and Type Approved to meet all regulations and directives, it's difficult to differentiate between them.
8,529
I was just responding specifically to # 14 which said that the changes at Witter had not included quality standards. Which is patently untrue. The modern facilities in Deeside, and Ellesmere established by the US owner, Horizon Global, embrace Witter, Westfalia and Rhino, and give lie to the comment that only the Witter name was transferred.
“Apparently, Witter is not Witter anymore as someone bought the name, not the quality standard. Tow Trust is committed to quality products and making the best they can. At least that's my understanding.”
4,253
I have had both Witter and TowTrust tow bars. The difference on a Sante Fe at least is the fact of a three bolt attachment for the cross bar to the chassis attachment.On each side. Where as the Witter had two bolts each side.
8,529
My Witter on a Sorento had four bolts per side. It was a fixed towball. Seems as if one Santa Fe model fell short despite Type Aooroval. Have Witter subsequently sorted it out or is it still two bolts per side?
3,243
In my opinion, it's a loophole in the regulations that although towbars are required to use the car maker's attachment points, they aren't obliged to use ALL of them
1,818
They are tested to the same standard as other makes which suggests there is no practical difference in them. In my case the £200 difference in quotes for fitting was the deciding factor.
