Just getting ready to return to caravaning after a long absence. We changed our car to a VW Passat 2.0 Diesel Estate in anticipation then placed an order for a Sprite Major 4 EB. I did check on one of the matching sites which said it was a good match however checking another recently showed it was over 90%.
Checking in to it in more detail my car has an unladen weight of 1541kg (includes 90% fuel, driver at 68kg and 7kg luggage) and the caravan MTPL is 1433kg which gives a ratio of 93%. I know this is still acceptable however my thoughts are -
My car will always have the two of us in it when towing so our combined weight of 162kg added to the car weight will be 1628kg, I religiously weigh everything before it goes in the caravan so assuming we have a total of 150kg of possessions and I split that equally between the car and caravan so my car weight is now 1703kg. My caravan MIRO is 1232kg with the added 75kg for possessions will be 1307kg. This gives a ratio of 77%. So I am assuming with careful weight distribution I can achieve a good match with the caravan and car. Would I be correct in my assumption? though reading a lot of the comments on the forum I will be to busy going over my caravan looking for quality/build issues.
