- Nov 16, 2015
- 12,552
- 4,701
- 40,935
Found this article about a new Petrol Engine that Nissan are playing with. Could be the answer for us tuggers, clean on Emmissions and high torque
http://dailym.ai/2i4e2nx
Where I live in the sticks a great many cars (in the wider sense) are towing things other than caravans - horse boxes, livestock trailers and open trailers loaded with bits of farm machinery. These tend to be rugged 4x4s like Toyota Hiluxes and the less tame versions of Land Rover. My own vehicle is a half-tame Jeep Grand Cherokee (the previous model) and it came equipped with a towbar and trailer electrical connections from the factory as standard; only a tow hook needed to be added. Such vehicles are always going to be available because there will always be a market for them, and there is no reason why electric versions of them cannot be made.Dodger524 said:One consideration in the tow car debate that I think is being missed is that few if any manufacturers actually design a car for towing.
excellent write up prof..i do see one fly in the ointment.. can anyone trust car manufacturers ? is this technology fail safe and reliable ,now would be a first alas ,well i would have said i fear the end for fossil fuel powered cars but i'm slowly coming around to electric as it keeps progressing in leaps and bounds and frankly for towing it could be a pleasure,as long as they keep progressing with the range a car can go between charges and of course work on being able to supply electric for charging on the mass scale needed whilst bringing charging times down .. its amazing what people come up with when the clocks ticking so there is hope all the drawbacks for electric cars can be solved in the very near futureProfJohnL said:Nissan and Toyota announcement of petrol engines reaching thermal efficiency of 40% is quite astounding. Nissan has approached it by varying the compression of the engine where as Toyota claims its achieved it by refinement of existing technologies.
Do these two developments change the long term prognosis for the IC engine? I'm not sure. Many developed countries are moving to zero emissions, and whilst these engines if they come on stream will provide a step change in efficiency, but as we have seen over the last couple of years, high efficiency engines still produce emissions - some are worse than earlier less efficient versions.
Politically the UK government has set out its position which is no IC engines in domestic car production by 2040, so that would seem to make any expenditure by UK producers to improve IC technology somewhat pointless.
But the UK car industry sells product across the world, so its most likely there will be export models that continue with petrol and diesel.
Nissan (Infinity) is of course largely owned by Renault, and there is already a significant sharing of technology and platforms between the two companies. Toyota and PSA also have some important links, so its highly likely that these two technologies will appear in European vehicles when they have completed all the design and testing.
For caravanners, it does seem to hold out some hope, but I suspect that the trend will be for cars to continue to get lighter, which will mean lower powered (better fuel economy) engines will continue to become more prevalent.
Datsun/Nissan have a strong heritage when it comes to making reliable cars, and even in the 1970 and 80's when their cars had a propensity for the body work to fall to pieces the engines and running gear rarely missed a beat. I am fairly confident they know what they are doing, but having looked at the examples of the technology, I do wonder how robust the system will be.
The big question for the UK buying public is will the Government relax it zero IC plans if car manufacturers can make significant improvements such as those above.
alan29 said:2040?
I doubt if it will my problem by then.
indeed and i still recall several write up 15 plus years ago on the subject including it being used to enhance the performance of diesels as a after market kit..also saw studies again around the same time for emulsifying diesel with 5 or 6% water at that mix NOX levels dropped and indeed gave a slight increase in power.. no doubt ad blu was thought to be the better option!EH52ARH said:Just been out with a, person from JLR. , the new tech is water injection,, old tech from aviation. Lets see what happens.![]()
Gafferbill said:......
Imagine that scene where a good number of vehicles are electric......their batteries would soon be flattenedhmy:
No joke for the occupants........no joke for the services rescuing people with potential hypothermia ......no joke clearing the road of vehicles that have no motive power.
Gafferbill said:......many cars were stranded on the M74 for up to 8 hours recently in sub zero conditions.
Their occupants kept warm by running their engines and this was essential to avoid possible medical emergencies.
The emergency services ferried fuel supplies to vehicles that had run out of fuel.
ummm how longs a piece of string after all all things being equal wouldn't the electric car run out of power first ,followed by the petrol car and lastly the diesel ? so you could say maybe diesel is the only way forward .very few modern diesel engines need to be manually primedRaywood said:Gafferbill said:......many cars were stranded on the M74 for up to 8 hours recently in sub zero conditions.
Good point, but if a diesel runs out of fuel it needs the system setting up again so may be petrol is the only answer in those conditions.
