All I can do is compare the three tow cars I have had since 2005, the first was a Kia Carens, 2 litre, loads of power, and when we swapped caravan to one weighting 1350 kg it towed it fine. However than found car only rated at 1250 kg for towing so swapped to Kia Sorento, although the Carens towed OK, the Sorento was so much better, old 2006 model, the max torque comes in at 2000 rpm and max horse power around 3500 rpm so theory says difference is the rev band one should use, but on a single carriage way the speed limit would then not allow the use of top gear, so in real terms the revs rarely exceed 2000 rpm.
So with the Carens that resulted in with slightest raise changing down, could of course left it in 4th gear, but one tends not to, with the Sorento that little extra power resulted in staying in 5th while cruising.
Now in theory our Jaguar XE could also tow the caravan, that is rated to tow 1800 kg, and being an 8 speed automatic the changing of gears is not an issue, however can't carry bikes and tow with the Jaguar XE as it does not use a tow ball with 3.5 inch centres between bolt holes.
Some times comparing cars one feels it is silly to reject one because it has no cup holders, however although petty it actually does make a difference. We would not have bought the Sorento had we got the Jaguar XE first, but now we have the Sorento we are keeping it to tow with. So advantage over the Jaguar XE
1) The 13 pin socket is easier to reach.
2) Can carry bikes and tow caravan at same time.
3) Can access boot space from inside car, so boot usable even after caravan hitched up.
4) Does not need extension mirrors it's wide enough.
5) Can see over hedges so more warning of on coming traffic.
6) Heavier so more stable.
7) Know it will go up any hill with low ratio box.
The Jaguar XE does far better miles per gallon light, and is automatic so no playing tunes on gear box, or at least if it does we don't know or care what it's doing, the reversing cameras make it easier to hitch up, I can actually see the ball, the suspension is softer the seats are more comfortable, and it is in theory a far better car. However still prefer to tow with the Sorento.
In both cases they are 4 wheel drive, so neither are likely to get stuck on a wet field.
In our case the Sorento is only used when we go on holiday or emergency at the moment lent my Honda Jazz to daughter in law, so I am using Sorento, but normally it just sits there.
I suspect most people do not have a dedicated tow car, I am sure some have an old Land Rover to tow with, but most want to use the car both for towing and general running around. And since it is normally used more for general running around than towing, if I had to get rid of one car, it would be the Sorento. But although Jaguar XE all set up for towing, I have never towed with it.
Years gone by, my dad smashed up his car, but caravan was OK, so we wanted to hire a car to tow caravan home, only thing we could find with a tow hitch was a Land Rover so we hired a LWB diesel to travel from North Wales to Scotland pick up them and caravan and return home on a long weekend.
Now towing with Land Rover was fine, but going up the M6 at 55 MPH flat out was not what I wanted to do, I had towed with Austin Gypsy, and never thought about it, grand tool, but we only used it without caravan local, when your driving 150 mile up the motor way it was another story.
Years ago my dad and uncle both towed caravans with low powered vehicles, dad standard 8 and uncle bonie and side car, and had to avoid steep hills and it was not unknown for my aunty to get out of side car and push, those days are gone. Today the manufacturer says how much you can tow, gone are the days when AA sent you route maps avoiding steep roads.
And yes we actually rejected a Vauxhall car because the of no cup holders. And the Duster rejected because I banged my head getting in, those under 6 foot may not have a problem, but those ladies under 5 foot may need a stool to help them get into the Sorento?
Towing a horse box your cars are very limited, horses are very heavy, but caravans are quite light in comparison so in most cases you don't need a car rated to tow between 3 and 3.5 ton.
