I would be grateful for some advice - hope I can explain ok. How heavy could the caravan laden weight be with a 1300 tow weight 52 nose weight kerb weight 1370 85% 1164 Hope someone can assist - thanx
If the towing limit is 1300kg and the noseweight 52kg then the maximum total weight of the caravan can be 1352kg. However, this would result in a weight ratio of 99%. If you wish to stay within the 85% recommendation, then the caravan may weigh, as you say, 1164kg.
