Towbar & the MOT
Well ...just had a MOT and the tow bar and electrics were examined and the electrics declared faulty....strange as its only 18 months on this vehicle,but the station said that the side lights wern't working ..but hey ho it wasn't a total failure only an advisory ( for now). So I'm lucky enough to have in the garage an old trailer board from my days of loading bikes on the back of the car...and plugged it in ...and lo and behold everything works..wierd.I can only think that plugging in and taking out the leads 'polished' up the socket points..so my advice is get the wire brush out and make sure those pins are sparkling before the advisory turns into a fail there and then.
Was that the 12n socket or 13pin socket ?
Trailer/caravan electrical socket
There will be a basic security/damage check of 7-pin sockets,
13-pin sockets will be subject to a full electrical connectivity check and incorrectly connected or inoperative circuits will result in failure.
The AA.COM
sorry not part of mot to plug test older sockets , and at pressent still not part of mot to plug test 13 pins , it may in future to check wireing
I have a detachable tow bar(an aftermarket version),if it's not on the vehicle when i have an mot will they still check the electrics?
"yes" because A the socket is still attached and B you still have a tow bar fitted, however only the 13pin socket should be checked for continuity on the MOT 12n and 12s plugs will only have the security checked as the equipment used by testers only has a 13pin plug on it at present,
the testing socket actually has the choice of testing both plugs on it , thr 7 pin and 13 pin , you plug an adaptor on it , it comes in a kit , but its not part of the mot yet
If you have 12N & 12S sockets on your car, all they get at MOT is a quick look at the security of the wiring. I watched my car being MOT'd last Friday.
