Parksy
Prof. John L posted a Caravan Club technical sheet in June 2011 which sets out existing law regarding towing mirrors.
To see John's information Click Here
Surfer,Surfer said:An EU Directive is not British Road Law so at the moment is a bit of meaningless garbage in the UK, but I get your point. I doubt whether there is anyhing specific in British regualtions regarding the use of extension mirrors except to say you must have adequate vision. There is no defintiion on "adequate" vision.
It wouldn't have become a Directive if the UK had vetoed it. Once it has become a Directive it must be incorporated into national law and this has been done.kelvin said:One of the problems with EU/EC directives is that member states have the power of veto and as such these thing have to have a rider that say adopted on ……….. We the UK use this veto more than most and therefore must be seen along UK legislation.
Parksy - Moderator said:Prof. John L posted a Caravan Club technical sheet in June 2011 which sets out existing law regarding towing mirrors.
Hi SurferSurfer said:Parksey do you think that hearsay evidence would stand up in a court of law? As I pointed out on that thread where John responded what the CC and an insurance company write is meaningless unless backed up by law. Until I see the regulation specifically defining the use of extension mirros, not exterior mirrors then i will assume what is written to be fiction. Incidentally the article that John copied and pasted referred to exterior mirros and not extension mirrors.
I am not disputing the use of extension mirrors which i think is a good idea but I am disputing some of the interpretations of the law when there does not seem to be anything specific relating to the use of extension mirrors. On my previous vehicle even with extension mirrors I could not see the back corner of our caravan although I had adequate vision of the adjacent lane. No issue with that on my 4 x 4.
Firstly, there is no such thing as EU legislation. It does not become legislation until it is ratified by national law, which it has done in the UK by corresponding amendment of the Vehicle Construction and Use Regulations. The law says that the vehicle must comply with the Construction and Use Regulations and this includes all applicable amendments. What you have quoted, Dustydog, is just one of those amendments.Dustydog said:Thus I suspect "technically" Surfer is correct. Is this not another matter like the good old "85% rule"![]()
Lutz reference to EU Legislation is probably valid if I am towing in Europe but I don't see how it can modify English Law without Parliament passing another Law???![]()
Thanks for that Lutz.Lutz said:Firstly, there is no such thing as EU legislation. It does not become legislation until it is ratified by national law, which it has done in the UK by corresponding amendment of the Vehicle Construction and Use Regulations. The law says that the vehicle must comply with the Construction and Use Regulations and this includes all applicable amendments. What you have quoted, Dustydog, is just one of those amendments.Dustydog said:Thus I suspect "technically" Surfer is correct. Is this not another matter like the good old "85% rule"![]()
Secondly, a mirror is a mirror. There is no distinction between requirements for the standard mirror and those applying to an extension mirror. If the standard mirror doesn't meet the regulations then an extension mirror must be fitted which does.
As I mentioned in my previous reply, the law doesn't have to refer to the use of extension mirrors. I therefore repeat my statement that if the standard mirror doesn't comply with the field of view requirements as laid down in the Construction and Use Regulations and defined in detail in EU Directive 2003/97/EC referred to in the said Regulations then it should be plainly obvious that a mirror must be fitted which does, i.e. a type approved extension mirror.Parksy - Moderator said:I don't think that the laws actually refer to the use of extension mirrors.
Exactly, Travelling Rooster. What constitutes adequate rear vision is laid down in detail in the EU Directive.TheTravellingRooster said:Hi to you all out there. I have not trawled all the way this subject but the one thing that occurs to me is that The Camping & Caravanning Club covered the issue of Towing Mirrors in their January 2010 monthly club magazine.
Apparently it is (at the date of publication) NOT a legal requirement to have towing mirrors,BUT however it is a legal requirement to Adequate Rear Vision. The logistics of which boil down to the ability to see that which is rearward at a distance of 4meters either side and at a distance of 20metres behind the driver NOT 20metres from the mirror face.
There was also a law in place that requires NEW CARS registered from the 26th January 2010 must use an 'e' or 'E' marked mirror with a number starting with 03* or 02 respectively.
It should be understood that only mirrors (standard or extension, as applicable) which fulfil the requirements of the Construction and Use Regulations can be described as providing "adequate" field of vision.Surfer said:.... but "adequate" is not defined .....
Be careful if you tow with the rear view camera switched on all of the time, it may be a traffic offence to drive in a forward gear with an active monitor if a police officer notices it. I think that the law was introduced to prevent lorry drivers from watching portable television sets whilst driving and technically it still applies to monitors connected to rear view cameras.chrisbee 1 said:.................. In addition I have a small blind spot mirror fitted to the top of the n/s aero AND a rear view camera on all the time (showing the road adjacent to the vehicle). Nothing sneaks up on me from behind!![]()
Surfer, as you seem to be questioning the presence of legally defined values, i.e. what constitutes an "adequate" field of vision, may I refer you to The Road Vehicles (Construction and Use)(Amendment)(No.4) Regulations 2005 which under "Explanatory Note" documents the implementation of Directive 2003/97/EC out of which I copied the sketch that is pasted in Travelling Rooster's thread.Lutz said:It should be understood that only mirrors (standard or extension, as applicable) which fulfil the requirements of the Construction and Use Regulations can be described as providing "adequate" field of vision.Surfer said:.... but "adequate" is not defined .....
