Towing Mirrors - know the law
Do you know the law on towing mirrors? If you do you may be shocked to find that up to half of caravanners either don't know it or totally disregard this essential safety rule. We have been contacted by Milenco, who are a leading manufacturer of caravan safety and security accessories and what they told us seemed so important that we have decided to write a tip page on the subject.
Many caravanners treat towing mirrors as something that they can do without but the law says different. There is a legal requirement for you to have mirrors that allow you to see clearly an area that is 4 metres wide from the side of your caravan at a distance 20 metres behind the driver. A caravan is significantly wider than a car even a large 4x4 and you simply can't comply with the law unless you fit towing mirrors.
Drivers of larger tow cars may think that they are OK because they can adjust their mirrors so that they have some rearward vision but what they see is simply not good enough. See the diagram below for a pictorial explanation of the legal requirement for towing mirrors. Milenco clearly have an axe to grind as they manufacture the required accessory but we feel this goes a little deeper and there is a genuine desire to improve caravan safety. We also have an axe to grind in that we want you to keep safe and make less claims. This is therefore part of our program of educated self interest. If we can make you aware of your legal requirements and persuade you to go out and spend £20 or £30 on a pair of towing mirrors we might save you from prosecution, and make you less likely to make a claim and who knows perhaps save someone's life.
