- Aug 10, 2008
- 233
- 0
- 0
Oh dear! Firstly, I have a diesel, its one of numerous diesels I have owned. Poisons coming out of the exhaust are irrelevant to the issue you were talking about.
So here goes. Reliability! Once diesels went hi Tech, then the reliability advantage dissapeared,indeed they do share a lot of the same electronics so its even Stevens there. But The diesel engine still suffers from soot build up, so the EGR valve is prone to failure, as is the turbo again due to soot build up, something that cannot be levelled on the petrol engine.
It appears because of its inheritance, low-down high torque characteristic, clutches and indeed the DMF, wear out far more rapidly than they do if fitted to a petrol engine!
So we already have two very costly units that brake more so on diesels, than petrol engines, turbo's at a grand and DMFs costing about the same it replace and fit.
Engine mountings, and gearbox mountings also suffer far greater wear on the diesel engine[more cost]Crankshaft pulley is another wear part,all those engine vibrations what not, another part that will need replacing far more often than that fitted to a petrol engine.
Then we come to the injection system [now this is hi tech and needs to be] The diesel injection system is an exceedingly expensive system, god forbid that going wrong,and again they go wrong more so than the cheaper petrol injection system does.
Now what about those new injectors themselves! To keep a head in the torque race [1800 odd psi going through them in the modern common rail]and as too not loose to much more ground in the BHP race, these things when they go wrong will indeed cost another small fortune around a grand for a complete set of 4 .
"last longer"!!!!! How long mileage wise do you want a engine to last? the modern petrol can go 200,000 miles with regular oil changes,and yet these new style service gaps and longer lasting oils for diesel [so to bring down service cost] are actually leading to all sorts of issues for diesel engines over 100,000 miles!.With wear levels in the camshafts, valves and valve gear now being worse than the same thing in petrols!
You said Seth..
"Diesels are less polluting than petrols,whether it be EGR OR SCR ,NOX gases have been done away with."
Diesel engines emit higher levels of NOX and you seem to have misplaced PM particulates! Although whilst i know what a egr is,[gas recirculating system ] That's not actually a gas! its a valve!.!
And incidentally modern petrol turbo's [not the monster bhp boys] have quite high toque settings at quite low rpm, so where on earth you get the peaky nature from I do not know! And given that a citroen xantia of circa 94/95? was tow car of the year with 92bhp and around 140 ft/Ib of torque, Then to go on about 225/232 ft LB of torque is being what everyone needs, is indeed rather misleading. The vauxhall vectra of 97-2002 had 151 ft/Lb of torque,and apparently was a decent tow car.
Matbe you are thinking of the BMW 2002 turbo [circa 1970s] or the saab 900 circa 1980! When you were thinking peaky all or nothing.
Like I said I like diesels I own them, but things are changing again, and now most investment is going into the petrol engine, just like most investment went in to diesel in the last decade.
Dustydog. LPG kits fitted to petrol cars, in a way it sort of doubles your mpg, as its only half the price of diesel/petrol.....
You said Seth..
