Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
Due to replace car and am likely to opt for Avensis 2.0 D4D. Can someone confirm noseweight limit is 75kg and also any views on the Avensis as a towcar would be appreciated.
Hello Martin. It would be unwise to rely upon the accuracy of information garnerd from listings such as these, especially where a statuory requirements exsists such as in load limits. Always check with the manufacture. Quoting this bulitin board if you are accused of over-loading would not be a defence.
Martin - in the towcar section, Practical Caravan for January says the Avensis 2.0 D-4D has a nose weight limit of 52kgs and a a max tow weight of 1300kgs ie it would seem useless as a towcar! Graham
