Do they make one that just does 2 wheels and has the range to get from the caravan wheels?I used Tyrepal.
Yes and you can get a range extender module for longer vehicles. They also have various option kits plus a very good spares range. Take a look at their website.Do they make one that just does 2 wheels and has the range to get from the caravan wheels?
Two problem I am running into one range from the caravan wheels to the dashboard and two ability to deal with 60psi.
Emove do a solar/usb system.Luckily I was sitting down when I looked at that🫣
Another thing I need is solar power as I'm not running any more cabling to it.
I never had an issues with Tyrepal, but I thought from your #5 it was too expensive for you.I found loads but have at present sent two back, one because of coverage and update timing, the other the manual bore no relation to the unit.
This is the cheapest ( did I say I'm a cheapskate ) I've found Tyrepal for, need to get something more for my CAMC membership.
At over £100 yesI never had an issues with Tyrepal, but I thought from your #5 it was too expensive for you.
Thank you for the offer JohnI have the car TyrePal car unit, not sure what model. It was supplied with my van in 2001 but I don’t think it was used much if at all as the van has been mainly sited as seasonal. The senders are internal but now have flat batteries. It will pair with external units. I intend to sell it, will dig it out when I get home on Saturday so I can see which model it is. It will be around £30 plus p&p.
Interested ??
This is what I had, it was sometimes a bit iffy on the NS caravan wheel as the display was on the opposite corner of the car. However after 3 years use on Saturday a sensor decided to let the tyre down overnight so I've decided to bin it.I have had tyrepal on my car and caravan for years, and have been very happy with it.
However I then sold the caravan and bought a PVC so thought I would take a punt on a cheapie from Ebay.
I paid about £16, it has a solar powered display and 4 sensors. It has worked faultlessly straight out of the box. I tried tge range and its certainly as good as the tyrepal set up.
That's the one my brother bought and sent back.I found loads but have at present sent two back, one because of coverage and update timing, the other the manual bore no relation to the unit.
