Tracker Alarm
Please can anybody let me know how many activators (black box) you got with your caravan. Just picked ours up today and only 1 box - should there be 2? Thanks
You'll have to excuse my ignorance as I'm replying for my husband as he is at work. There's a tracker on it but there is also an alarm on it and when you press the button on the box (its like a car alarm box) it activates the tracker and the alarm at the same time. The book says you should have 2 boxes but the supplier has said that bailey only provide 1? Hope this explains it clear!! Lol, thanks Andrea
I presume you are talking about the alarm remote?if it is sounds like you will have to order another one from Baileys.I think you should have a master key with the alarm so you can switch the alarm off if the remote batteries fail.
Do you not get a type of master key with the alarm?
Elddis have a hard key that you put in a receiver inside the van if you ever lose your remotes.
What would you do if the blipper got damaged or the batteries failed,not only would the alarm being going off it would also be sending a distress signal to the tracking company.
Mikey
No there is no master key just the 'blipper' so it looks like we will have to buy another just in case!! Thanks
Tracker Alarm!!!!!
I have tracker fitted to my New Bailey Senator Wyoming but it is not an alarm. It only works if the vehicle is stolen. There is no audible alarm with it at all. I must say I thought there should be though. Do they do two products, one with alarm and tracking device and another with just the tracking device.
By the way mine only came with one Blipper (like that name for it )
Mikey V
Mike I presume its the same as my Indiana the alarm is turned on and off with the tracker remote control if you drive it off with the tracker set the alarm will start after about 10 to 20 seconds after 5 minutes with the alarm going the tracker is activated according to the book.Have done this accidentally and it did set off.The PIR that was on series 5 alarm is an extra which we havent bothered with only got one remote as well the other is guess 'an extra'
