Hello Veronica,
You call for information about a 'transformer' to power your 12V equipment. As has already been pointed, to define the best product we need to know exactly what you want to power up.
Most caravans these days have items like water heaters, fluorescent lights, and water pumps. All these require DC (Direct Current) power such as a battery provides.
A 'Transformer' only produces AC (Alternating Current) and if you were to connect any of the above items, at best they would not work and at worst they may be damaged. A 12V transformer is only a notional value, as in practice it would actually produce an output voltage swing of +16.8 and - 16.8V or a peak to peak swing 33.6V! not much like 12V dc. So a transformer by its self is not suitable to run the 12V equipment in a caravan.
Older caravans (pre mid 1980's) were mostly fitted with a battery charger. Such devices did produce a DC current, but it was a both unregulated, and unsmoothed and would in its self not produce enough power to run the 12V devices in the caravan, in other words its current out put was weak and lumpy' The unloaded output voltage could be as high as 25V which is also not suitable to run the caravan items that contain delicate electronics.
As the name 'charger' implies it was designed to have a battery connected. The battery provided three, essential elements. Firstly it loaded the charger and controlled the peak voltage, The battery also provide the necessary smoothing element to maintain the current to the items between the lumps of power from the charger, and it also provided the current capacity to run the items when the load would have been to great for the charger by its self.
After the 1980's, the industry started to fit more competent devices called power supplies. These contain all the necessary bits to ensure the output is fully controlled. Usually the output is 13.8V, and this is smoothed and regulated, They also usually have sufficient current capacity to run many items in the caravan without a battery.
A battery can still be used and it would be essential if you intend to use the caravan on sites without mains hook ups. The 13.8V out put from the power supply is sufficient to keep a battery well charged.
If you are not fully familiar with the above, then I strongly suggest that you have a competent fitter to choose and install the best device for you. Badly wired 12V equipment is just a capable of causing a fire as is 230V mains.
